Einziehfahrwerk
Einziehfahrwerk
Ich habe auch ein Lösungsvorschlag:
Elektrisches Einziehfahrwerk von Hobby King
Servoless Retract with metal trunion with 44mm x 41mm Mount (2pcs) 90 Degree - Features Auto Cut Off and pre-installed 5mm Oleo Mounting Pin
Operating Voltage: 4.5~6.0V
Supported Model Weight: up to 5kg
Mount Plate Dimensions: 44mm x 41mm
Scew Hole Spacing: 36mm x 33mm
Depth: 28mm
Length: 74mm
Pin: 5mm
Weight: 72g each
PRODUCT ID: 225000018
This servoless steerable nose retract features a metal trunion and a 44mm x 41mm mounting plate. It's designed for models weighing up to 5kg. It includes a pre-installed 5mm pin and steering assembly.
Screw Hole Spacing: 36mm x 33mm
Depth: 28mm
Length: 74mm
Pin: 5mm
Weight: 77g
PRODUCT ID: 225000017
Fahrwerksbeine aus Hongkong nicht Hobby-King
Struts made out of durable aluminum
CNC Machined using 6061 Aircraft Grade Aluminum
Light weight rubber tires
Nose Gear Tire: 45mm
Main Gear Tires: 48mm
Can be used on any rc aircraft with a flying weight up to (4000 g
Struts Weight: 165g
hier gibt es auch ein Video
http://youtu.be/n2r3HRUSgjI
Gruß Stefan
