Ich selber gebrauche RCGroups fuhr Info.
Dies ist was ich gefunden habe fuhr mich selber als erste Info, Hofe das englisch kein Problem ist fuhr dich????
CG (Goonic33)
If you look in the manual the CG they recommend is on the forward most wing mounting screw. The is actually the rearward CG and is borderline tail heavy. move it to the middle of that range which is between that screw and the leading edge of the wing. You will be fine in there.
FLAPS
Just a heads up, with flaps at half (30 degrees) to full flaps (60 degrees) she'll surprise you and float in...more than you would expect. I like to land with between a 1/4 to 1/2 flap.
Maiden done. Absolutely no surprises!!! Do not use more than 1/2 flap and half speed brakes on approach, you will need about 1/2 throttle even with that.
I set up my mid rates half way between published rates and flew with them and low rate rudder. Flew great, stable, good roll rate ( I like a fast rate) and good elevator authority.
