Ausführlicher Baubericht WILGA (Frisch 1:3,5)
Does anyone know if kempf modelbau is out of business - I have tried ordering the lamel intakes in front of the engine and top intake on cowling
For 2 months and 3 emails no response from them ?!
Perhaps the lamels fit from tomahawk ?
What‘re these for profiles, Polystyrol? How you fixed them, just CA-glue?
Hi Thomas
It is styren profile 90 degrees 3mm and half round 4mm
All wood surfaces is covered with 49g glass sprayed with spray filler and father multiple layers one time white lack color then I used CA glue to add them on - it will not work directly on the raw glassfiber as the will easy jump off with small force - but after filler and 2 layer paint the CA bond real good to the paint - after that paint it all 3 times
