very nice photos, josin!
This weekend (18 and 19 Nov) I was able to release my Raven (after two years from buying it). The wether was very good: 16 degrees, wind zero, no clouds. The first flight was giving me more emotions but in the end it was proven there were no reason for them. For trimming was necessary only one click up on the elevator, everything else was ok. It flyes neutral also on the back and in knifeedge(?) (messerflug) is neccessary only a very little down elevator (I think it is a litle bit heavyer in the nose). For now I am very content with it and I am waiting for the next weekend. What about I am not content is the setup of the engine. Is a new DA50 with about 3l of gas consumed. The low needle was opened more in the breakin process and now I was closed it back to get more power. The problem is the acceleration line: on 50% of the servo path, it runs to 80% of the power. The propeller is a Mejzlik 22x10 and the max RPM is 6700. Know somebody what could be the problem? I am interested if it comes from the setup or not, or if it is normal to behave in this way. If it is normal, than I will adjust the gas curve from the remote...that's it.
