NEU/LEOMOTION 4635 mit Idealisierungs Tipps!
Cohesive
Choices with individually wound coils are (D),(Y), (DIID), (YIIY), (DIIDIIDIID),(YIIYIIYIIY). Look
*** Titel angepasst! ***
Cohesive
And so we reworked it to be a dual layer with 3 turns of dual 16Ga. conductors. The Kv should be 333 in delta and 385 in parallel wye. 4 of these conductors per motor terminal bring back a preece rating of 468 amperes. This medusa's head uses a single coil winding system with no crossover wires in the slot. The space could hold in a single strand at least 7 turns. I have all the phases organized for termination .
Cohesive
Thats exactly right Walter. Every piece goes in a bucket and when the bucket is full it goes to recycling where copper brings a penny. I dont care about the negativity anyway. Anyone worried about the copper can back in the brinks truck and sweep the floor. Hopefully they get rich. : Rolleyes: who cares about the few snipped pieces that wont add up to a meter of 16 ga wire.. its blasphemous....!!!
Gerd Giese
Meines Wissens werden Kupferabfälle wiederverwertet...Gruss, Walter
Um Recycling ging es mir ganz und gar nicht ... :p
... egal, aber schön anzusehen wenn Wicklungen so akurat geführt sind und schaun wir mal
(wäre für mich wichtig!) ob wir anschließend auch vor/nacher Leistungsdaten erhalten! ;)
Cohesive
Right thats certainly more important and interesting than the copper on my floor. Are u hoping it fails? Seems like it.:)
Cohesive
It really would have been nice to add 1 more strand to the single turn. The 3 strand would be capable of carrying more than the primary two so they would be the primary is the bottle neck. In a wye wind they could give triplen more room to gather as the bundles. Maybe its a horrible idea. Another turn would certaiinly fit but it is a dual wire that would have to traditionally.
Cohesive
This was purchased az a raw stack and im not sure if neu motors actually sells a 4635 which this is. Im sure it is a good motor in stock form if they do. I could easily give 500 kv with this motor with a very large single strand the motor would be simply beautiful. But for this to throw away skin effect a slot die to press braid to the slot shape would be best or maybe rectanglar wire laid horizontally and vetically in the slot. This could possibly have benefit to conductor losses in the right orientation. The jury is not in yet. There is time still.
Cohesive
I have all the starts and end consolidated for the phases. You see Gerd? All the copper you see wasted will bring you .45 Euro
Danke
Hubert
Cohesive
Christmas of course, and without meeting any one else's time frames, absent of their development money mine will be a happy one. Hope yours will be too. All the gear is here except for the props and we will test it when we get ready.
Till then enjoy your holiday!
Cohesive
Stocking stuffers......
The most compact! lighter! 40kW! APD matches the NEU decorum quite nicely.:p
Cohesive
**** gelöscht, siehe Nutzungsregel 1.8 - Gerd ****
A10X23 Nue/GM,Big Bruce Racing 12x25 saw tooth, and Marcel Schlage 11.5x25 saw tooth. Spammers can easily fit 3 (2+1) DL for 333Kv. 2x1.828mm will look pretty to spam seekers, and in a delta or parallel wye it's 398 amperes Preece. In a parallel delta it is 796 amperes Preece :p
attachment.php
A10X23 Nue/GM,Big Bruce Racing 12x25 saw tooth, and Marcel Schlage 11.5x25 saw tooth and 3 (2+1) turns in DL is 333Kv. 2x1.828mm in a delta or parallel wye is 398 amperes Preece. Parallel delta 796 amperes Preece :p
ATTACH]
attachment.php
Ja, das ist wirklich "spam" von der Allerfeinsten Sorte.Nicht so ein Billigdreck, wie Du auf dem ersten Foto zeigst!796Ampere!WOW!Damit wirst Du uns allen davonfliegen.Ich weis nicht wie es den richtig schnellen Speedpiloten geht,aber mir schlottern jetzt schon die Knie vor Angst.Du wirst mit dem Setup ganz sicher den Weltrekord an Dich reissen!Schade, dass uns das nicht eingefallen ist, dieses Supermaterial zu verwenden.:cry:
Cohesive
Say cheese....shudder click. Who said any of that :confused: I guess because you singularly don't do your own work thus you are stuck dancing to the pipers tune on inferior ones???
Happy Holidays....
yes Cohesiv this propellers look good vor testing the drive , for the speed drive you will get the propeller we had lasersinter the mold with the design from munich university. With the new wire i will inform you ,see your e-mail.
@StefanV, frohe Weihnachten und ein gutes neues Jahr.
Ab 01.01.2019 müst Ihr euch ja nichtmehr hier im RC Network Forum tummeln , Ihr bekommt ja dann das Expertenforum von Okon in China ( da lesen dann nur noch zig tausend Chinesen im Hintergrund mit) . Da braucht Ihr euch nicht mehr auf Forumseiten herumlangweilen deren Inhalt Euch eh langweilt da ihr eh das bessere Material habt.Und Danke für deinen Beitrag der viel Nützliches zu Cohesivs Motoren beigetragen hat. Nennt man das nicht trollen ?
Happy Amps Christian
Christian Lucas,Woher hast Du diese sehr interessante Information?Leider kann ich kein chinesisch :(
Auch Dir ein frohes Weihnachtsfest,
Gruß Stefan
Hi Stefan,
off topik on“, da hat mich ein Canadier angefragt ob ich weis wo er sich anmelden kann. Angeblich hat das der Okon im rcgroups irgendwo geschrieben, frag mich nicht wo , ihr seid da doch ehr verbunden. Kann aber auch sein dass du nicht zu dem Expertenkreis gehörst und deshalb nicht unterichtet wurdest. Wie üblich halt . off topik off.
