Entschuldigung für mein Deutsch Ich benutze Google Translate.@ tommes ,Glückwunsch auch von mir.
Magst uns was zu deiner Ausstattung erzählen
@gquiring
Meinst du die fürs Seitenruder?
Dafür liegen normale Augenschrauben dabei.
Danke, das Englisch ist eine viel bessere Übersetzung, das macht jetzt Sinn.have a look: https://www.multiplex-rc.de/Downloa...itung-alpina-4001-elektro--de-en-fr-it-es.pdf it is the first 4001, but may be it can help you...
12mmGrüß dich.
Wie mm gehen die Torsionsstifte den in den Flügel rein?
Gruß Martin
My name is Gary Quiring. I ordered a 16x10 RFM prop. Are the Graupner nylon props safe with these larger motors? Or do I need to stay with carbon props?Hi gquiring,
you have a real name as well?
Makes communication easier in my eyes.
6S shouldn't be a problem for the Champ.
As long as you are below 6kg in my opinion its OK.
I am using the Leopard in my 5001 with 6S at a 18*8.5 GM Carbon prop.
This will be sufficient for vertical climbing with the 4001.
With the 18*10 CamProp I would use 5S/4000.
In this case you are at about 5.5kg what is the optimum for a 4001 (imho).
I used a 4S Kontronik GearDrive in my old MPX Alpina Magic which also was impressive at that time (nearly 15years ago ).
I hope this helps a bit.
