For sale: Viper MK2 parts
Today I was out of luck.
I made a long flight for a photo session and I wanted to land because the battery was near empty. On the landing circuit the wind direction changed and I needed land from the other side of the field. Because I was flying with minimum throttle and away from me to make a new approach from the other direction I was not able to see the speed of the Viperjet. I wanted to make a 180degrees turn to land and a combination of slow speed/stall and wind on top of the wing when cornering smashed the plane with the nose in the ground.
The front part of the fuse is heavely damaged. The wing, cockpit and stabilizer are in 100% perfekt shape (the cockpit has a little corner with no paint).
Because the Shreiner Viperjet is 299euro I do not think I am able to get a new fuse from Axel for a cheap price. This is the reason why I want to sell the wing,stabilizer and cockpit as a replacement part for you who are not able to get new parts from Axel Schreiner. If somebody is interested in the fuse I can send this for free with a good part.
Please be kind enough to buy only the part you need. Like this I might be able to help 3 pilots.
I Think the servos on the wing are not a problem for a minifan (it is easy to remove them). Same thing for the elevator, You can remove the steel with a Dremel tool.
Sorry for the qty of the photos. The camera is getting old.
Send me a PM if you are interested.
