Hmm...ich kopiere das mal hier rein:
CG scale for F3F & F3B models
Olav Kallhovd 2016-2017
CG Scale main components:
1 pc load sensor front YZC-133 2kg
1 pc load sensor rear YZC-133 3kg
2 pc HX711 ADC, one for each load sensor (128bit resolution)
1 pc Arduino Nano
1 pc 16*2 HD44780 LCD + I2C-Adapter
or
1 pc 0,96" SSD1306-kompatible OLED with 128x64px
3D printed parts
Max model weight with sensors above: 4 to 4,5kg depending on CG location
5 kg at a CG of 83,9mm with Sensors above
Update 10.12.2017 by T. Reik I2C-Output for LCD
Update 01.02.2018 by T. Reik added OLED-Display
#define vCGscale "v1.0"
#include <HX711_ADC.h>
https://github.com/olkal/HX711_ADC can be installed from the library manager
Number of samples and some filtering settings can be adjusted in the HX711_ADC.h library file
The best RATE setting is usually 10SPS, see HX711 data sheet (HX711 pin 15, can usually be set by a solder jumper on the HX711 module)
RATE 80SPS will also work fine, but conversions will be more noisy, so consider increasing number of samples in HX711_ADC.h
//LCD
/*sketch for PCF8574T I2C LCD Backpack
http://tronixlabs.com/display/lcd/serial-i2c-backpack-for-hd44780-compatible-lcd-modules/
Use library from
https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads
#include <LCD.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x3F,2,1,0,4,5,6,7); // 0x27 is the I2C bus address for an unmodified backpack
Uses library from
//OLED
Library and Example at Adafruit
https://learn.adafruit.com/monochrome-oled-breakouts/arduino-library-and-examples
-> To save RAM here the "lighter" ASCII-Only-Library (SSD1306Ascii) from William Greiman is used
Published here:
https://github.com/greiman/SSD1306Ascii
#define I2C_ADDRESS 0x27 // 0x3C or 0x3D are common I2C bus addresses
#include <Wire.h>
#include "SSD1306Ascii.h"
#include "SSD1306AsciiWire.h"
SSD1306AsciiWire oled;
//HX711 constructor (dout pin, sck pint):
HX711_ADC LoadCell_1(A2, A3); //HX711 pins front sensor (DOUT, PD_SCK)
HX711_ADC LoadCell_2(A0, A1); //HX711 pins rear sensor (DOUT, PD_SCK)
byte ledPin = 13; //Onboard LED
byte batRefPin = A6; //Batt Input
String sBattvalue = "";
String sVal = "";
String vString = "";
char toLCD[20];
int output; //0=Serial Terminal, 1=serial Output to LCD-Arduino, 2=I2C-LCD-Output
boolean ledState;
long t1;
long t2;
long t3;
const int printInterval = 500; // LCD/Serial refresh interval
//*** configuration:
//*** set dimensional calibration values:
const long WingPegDist = 1198; //calibration value in 1/10mm, projected distance between wing support points, measure with calliper
const long LEstopperDist = 300; //calibration value 1/10mm, projected distance from front wing support point to leading edge (stopper pin), measure with calliper
//*** set scale calibration values (best to have the battery connected when doing calibration):
float ldcell_1_calfactor = 994.1; //CG-weiß: 952.0; // CG-Gold: 1096.0, CG-Weiss: 952.0; user set calibration factor load cell front (float)
float ldcell_2_calfactor = 708.1; //CG-weiß: 727.0; // CG-Gold: 722.5, CG-Weiss: 727.0; user set calibration factor load cell rear (float)
const long stabilisingtime = 3000; // tare precision can be improved by adding a few seconds of stabilising time
const long CGoffset = ((WingPegDist / 2) + LEstopperDist) * 10;
void setup() {
output = 2; //change to 2 for I2C-LCD, output = 0 for Serial terminal (for calibrating), 0=Serial Terminal, 1=serial Output to LCD-Arduino, 2=I2C-LCD-Output
// activate I2C-LCD module ################
lcd.begin (16,2); // for 16 x 2 LCD module
lcd.setBacklightPin(3,POSITIVE);
lcd.setBacklight(HIGH);
// activeate OLED module ################
Wire.begin();
oled.begin(&Adafruit128x64, I2C_ADDRESS);
oled.setFont(System5x7); //5x7 = 10X14px + 2px dazwischen
Serial.begin(9600);
//Startup LCD
lcd.home (); // set cursor to 0,0
lcd.print("CGscale RCN ");
lcd.print(vCGscale);
lcd.setCursor (0,1); // 1.Zeichen, 2. Zeile
lcd.print("tare... ");
//Startup OLED
oled.set2X();
oled.println("CG-Scale");
oled.print("RCN ");
oled.println(vCGscale);
oled.println();
oled.println("tare... ");
//Startup Serial-Monitor
Serial.print("F3X COG scale ");
Serial.print(vCGscale);
Serial.print(" ; ");
Serial.print("Bat: ");
int batval = readBattVoltage();
Serial.print(batval / 1000);
Serial.print(".");
Serial.print(batval % 1000 / 100);
Serial.print(batval % 100 / 10);
Serial.println("V");
if (output == 0) { //if output to serial terminal
Serial.println();
Serial.println("Wait for stabilising and tare...");
LoadCell_1.begin();
LoadCell_2.begin();
byte loadcell_1_rdy = 0;
byte loadcell_2_rdy = 0;
while ((loadcell_1_rdy + loadcell_2_rdy) < 2) { //run startup, stabilisation and tare, both modules simultaneously
if (!loadcell_1_rdy) loadcell_1_rdy = LoadCell_1.startMultiple(stabilisingtime);
if (!loadcell_2_rdy) loadcell_2_rdy = LoadCell_2.startMultiple(stabilisingtime);
LoadCell_1.setCalFactor(ldcell_1_calfactor); // set calibration factor
LoadCell_2.setCalFactor(ldcell_2_calfactor); // set calibration factor
pinMode(ledPin, OUTPUT); //led
digitalWrite(ledPin, HIGH);
//Displays aufräumen
oled.clear(); //Clear OLED-Display
// ############# Battvoltage #####################
int readBattVoltage() { // read battery voltage
// Batteriemessfunktion
long battvalue = 0;
battvalue += analogRead(batRefPin);
battvalue *= 4883L; // 8789L analog reading * (5.00V*1000000)/1024 (adjust value if VCC is not 5.0V)
battvalue /= 317L; // 320L this number comes from the resistor divider value ((R2/(R1+R2))*1000)/noof analogreadings (adjust value if required)
return battvalue;
void flashLED() {
if (t2 < millis()) {
if (ledState) {
t2 = millis() + 2000;
ledState = 0;
else {
t2 = millis() + 100;
ledState = 1;
digitalWrite(ledPin, ledState);
void loop() {
//library function update() should be called at least as often as HX711 sample rate; >10Hz@10SPS, >80Hz@80SPS
//longer delay in scetch will reduce effective sample rate (be careful with delay() in loop)
LoadCell_1.update();
LoadCell_2.update();
// calculate CG and update serial/LCD
if (t1 < millis()) {
t1 = millis() + printInterval;
float a = LoadCell_1.getData();
float b = LoadCell_2.getData();
long weightAvr[3];
float CGratio;
long CG;
weightAvr[0] = a * 100;
weightAvr[1] = b * 100;
long weightTot = weightAvr[0] + weightAvr[1];
if (weightAvr[0] > 500 && weightAvr[1] > 500) {
long a = weightAvr[1] / 10;
long b = weightAvr[0] / 10;
CGratio = (((a * 10000) / (a + b)));
CG = ((((WingPegDist) * CGratio) / 1000) - ((WingPegDist * 10) / 2) + CGoffset);
else {
CG = 0;
// if output = 0: Scale-Mode to serial . print Sensor-Values #######################################
if (output == 0) {
if(Serial.available()) // ++++++++ Serial Calibration-Factor-Edit +++++++
{ String temp = Serial.readString(); // ++++++++ USE A+200 in ingrease FRONT Loadcell +++++
if (temp.substring(0,1) == "A") // ++++++++ Or B-200 to degrease REAR Loadcell +++++
if (temp.substring(1,2) == "+")
ldcell_1_calfactor += temp.substring(2).toFloat();
else if (temp.substring(1,2) == "-")
ldcell_1_calfactor -= temp.substring(2).toFloat();
if (temp.substring(0,1) == "B")
ldcell_2_calfactor += temp.substring(2).toFloat();
ldcell_2_calfactor -= temp.substring(2).toFloat();
Serial.println("New Calfactor will be used");
Serial.print("Faktor Front: ");
Serial.print(ldcell_1_calfactor);
Serial.print("; Faktor Rear: ");
Serial.println(ldcell_2_calfactor);
delay(500);
//Take it as new Value
} // ++++++++ End Serial Calibration-Factor-Edit +++++++
for (byte a = 0; a < 2; a++) {
Serial.print("weight_LdCell_");
Serial.print(a + 1);
Serial.print(": ");
long i = weightAvr[a];
if (i < 0) {
Serial.print('-');
i = ~weightAvr[a];
Serial.print(i / 100);
Serial.print('.');
if ((i % 100) < 10) {
Serial.print("0");
Serial.print(i % 100);
Serial.print(" ");
Serial.print("CG:");
Serial.print(CG / 100);
Serial.print('.');
Serial.println(CG % 100);
// Scale-Mode with OLED-Display --------------------------------------
//Header
oled.set1X();
oled.setCursor(0,0); //1 col = 1 Pixel, 1 row = 8 Pixel
oled.print("CG-Scale RCN ");
oled.println();
oled.print(" - Calibrate -");
oled.setCursor(98,2); //1 col = 1 Pixel, 1 row = 8 Pixel
oled.print((readBattVoltage()/10));
//Content
oled.set2X();
oled.setCursor(0,4); //1 col = 1 Pixel, 1 row = 8 Pixel
oled.print("A: ");
oled.println(a);
oled.print("B: ");
oled.println(b);
// Scale-Mode with LCD-I2C-Display --------------------------------------
vString = a;
for (int i=(vString.length()); i <= 16; i++){
vString = vString += " ";
lcd.print(vString);
vString = b;
lcd.print(vString);
// Anzeige von Werten auf LCD und OLED. Print Calculated Values #######################################
else if (output =! 0){
//OLED-Header
oled.set1X();
oled.print(vCGscale);
// ----- Anzeige Gesamtgewicht - 1. Zeile
vString = "WT: ";
if ((weightTot/100) < 1000 && weightTot > 0){
sVal = weightTot;
vString = vString += (weightTot/100);
//vString = vString += sVal.substring(sVal.length()-2);
vString = vString += ",";
vString = vString += sVal.substring(sVal.length()-2, sVal.length()-1);
else {
vString = vString += (weightTot / 100);
vString = vString += "g";
for (int i=(vString.length()); i <= 10; i++){
lcd.print(vString);
oled.set2X();
oled.println(vString);
// ----- Anzeige Batteriespannung - Ende 1. Zeile
if (t3 < millis()) {
t3 = millis() + 1000;
sBattvalue = (readBattVoltage()/10);
vString = sBattvalue.substring(0,sBattvalue.length()-2);
vString = vString += sBattvalue.substring(sBattvalue.length()-2, sBattvalue.length());
vString = vString += "V";
//LCD
lcd.setCursor (11,0); // 12..Zeichen, 1. Zeile
lcd.print(vString);
//OLED
oled.set1X();
oled.print(vString);
// ----- Anzeige Schwerpunkt - 2. Zeile
vString = "CG: ";
/*if ((CG/10) < 1000){
sVal = CG;
vString = vString += sVal.substring(0,sVal.length()-2);
vString = vString += "mm";
lcd.print(vString);
oled.set2X();
oled.setCursor(0,6); //1 col = 1 Pixel, 1 row = 8 Pixel
flashLED();
