I mained today the omega, its very good flyer, im used to fly an xplorer and this smaller one liked a lot .
Only made short fligth because the motor was not stopping (no brake), i have a problem with that because i use the roxxy esc programmer, go to brake menu and set to "on" but the value seems not to be settled to the controller as i connected again go to brake menu and saw "off"..... I read the instructions and found no reference on doing something special to set the values to esc like pressing a button or something.... maybe im missing something??
Its need to do something special to change the value of a roxxy esc using the programmer?? (more than selecting the correct value on screen )
Also noted that the engine comes down hot (i only use 6sec burst), its normal?
Thanks!
Thanks!
