TonyRay 1998
Hi everyone, I'm Tony. This is my Kranich II, It's y new project recently. I start to build this glider on June,2022. It's 1/6 scale and 3 meters wingspan. I will show the complete build process in this topic
First is designing work, so many parts
Fuselage design, profili is SD7032
Instrument panel.
Let Start, In order to make these two parts easier to build, it does not use the process of bending metal pipe I found that laser-cut plywood are fine enough to achieve the desired results.
Thanks to the auxiliary bracket, the fuselage is accurately to make.
Cover the fuselage with 2mm balsa
Finished
Instrument panel.
Finished
