GliderKing1
Time to complete the PRIME Electrical fuselage.
First picture shows the bottom side of the fuse and here you can see that the tow hook space is closed and a balsa piece is glued in place, the small open space is the ballast chamber. Pic 2 shows the servos I´m useing, the BL-motor is a Leopard 2826- 1150kv with a 31mm spinner and foldable propeller 9,5. My motor setup is a bit of "overkill" but I like the "need for speed"!
The fuse is a bit tight for this motor so I had to sand down the inside of the fuse a bit and I have built upp the underside of the fuse front bottom appr. 6mm´s and in front this gives me an opening for air cooling, se pic3.
Pic 4 / 5 shows the fuse contour with the BL-motor mounted
Pic 6 / 7 shows the difference between Thermal and El-fuses
Pic 8 / 9 shows the covered El-fuse
