!! Neu bei PAF !! KST-Servo CM633MG # 4,8-8,4V / 9-15kgcm / 15mm / 35g
!! Staffelpreise ab 2 Stück !!
KST CM633 V6.0 Technische Details:
Rated Voltage: DC7.4V
Voltage Range: DC4.8V-8.4V
Stalling Torque: 9,0Kgf.cm@4.8V
12,0Kgf.cm@6.0V
13,8Kgf.cm@7.4V
15,0Kgf.cm@8.4V
Speed: 0,14sec/60°@4.8V
0,11sec/60°@6.0V
0,09sec/60°@7.4V
0,08sec/60°@8.4V
Start Current: 1.85 A@4.8V
2,65A@6.0V
2,95A@7.4V
3,25A@8.4V
Working Frequency: 1520us/333Hz
Default Travel Angle: ±50° =100° Total
Temperature Range: -10°……+65° C
Soft Start: Programmable
Motor Type: Coreless DC Motor
Gear Set Material: Metal Gear
Position Sensor: Potentiometer
Ball Bearing: 2BB
Case Dimensions: 33mm*15mm*30mm±0.2mm
Weight: 35g±10%
Programmable with KST-Tool 3 and KST-Tool 5
