Hi,....
Ich hatte den Inside mit Tesascharnieren auf allen Rudern übernommen. Ist bei dem Modell nicht empfehlenswert. So hab ich alles neu bebügelt und die Ruder gleich mit an.
Gruß Hans
Könnte jemand erläutern warum tesascharniere nicht gut sein sollen?
(Ich bügel das erste mal und mir wurde geraten die ruder mit scharnierband anzuschlagen)
Don't worry for your english and thank you for your opinion especially on the motor choice!@iwilz ,good morning
My english is not good,but i will try to help you .
Also other motor/esc combinations with round about 200-300watt can be installed.
Your motor is strong enoung,but it has a back-mount-screw-system(sorry i dont know the english word for it)you need a motor with front-mount,mybe you can loosen the screws and push the axle through the motor.
the esc is ok(but look on the energie for the 8 servos,it must be strong,,höllein have a cheap 40A esc with 8/20A for servos)
To motors:
The most brushless motors WITH screws on the axle can be converted.
Some times the axle is glued in too,then heat can help.
Maybe try it on a old motor,with light straight hits with the hammer.
No worry,the direktion of the installation is right :-)
Hope you can understand my english
Greets...
Hi @Mario12, i understand what you are saying and yes i've already seen some piece of tape also in other photo of Inside or similar gliders but i thought it was not an "official" solution.Hi, the wing outer parts holds by the electrical connectors and a pice of tape.
i dont know for what is it.
