hacker A 60 24s v2 - 11 lipo?
NICATO
Hi everyone,
I'll explain my situation:
I built a prototype retractable engine for a glider, setup is:
- hacker motor a 60 24s v2,
- regulator jeti spin 99 opto (exuberant power)
-10 lipo from 5200 mah.
My power system provides only 1 half propeller 20 x 14.
With my setup I get to consume about 36 amps and produce over 1400 watts.
I wanted little more power, so a few more turns motor.
I can't change the propeller,(other problem:( )
I want to know if increasing the lipo from 10 (42v) to 11 (46.2 v) because the ampere below the maximum specified by hackers, I can use the engine or there is the risk of burning, seeing the low amps I can try to use it like this.
it is a prototype, therefore subject to improvements. :)
thank you all
Nicola
Hello,
How much KV has your motor?
You can use a 3-bladed prop with same diameter and you have more Power/thrust.
Or you test an 11S Lipo on your setup, and test ampere? and the temperature, because the 36A is very low now. :)
Hacker said :
ESC: 77 bis 90A
and 1900 Watt (max)
for this Hacker Motor.
Greets Alex
NICATO
Hello,
Hacker said :
ESC: 77 bis 90A
and 1900 Watt (max)
Greets Alex
hi Alex,
kv volt is 195
Unfortunately i can't change the propeller. (half propeller!....type schambech) for this that consumes is only 36A.
but at 11 lipo could I burn the motor?
Hello,
not too high voltage will kill your motor, only too high ampere will kill him.
I would test it with 11S and check ampere with watt /amperemeter.
You can write your Motor Setup, in the propeller Calculator.
What is a half propeller?
1 Blade, two Blades? Shorter blades?
(20x8)?
You have not enough room to the ground with a bigger prop?
Propeller (motor) Calculator :
You can see exact your motor in the list at the top?
Search your Propeller...
And you write your 11S Lipo there , and click enter! ;)
... vielleicht nutzt ja hier noch wer den Hacker Motor aus der Überschrift, und weiß was ein "half propeller" ist, und wieviel Durchmesser und Steigung dieser Motor verträgt?
Und ob ein 11S Lipo der Motor vertragen wird, da sie mit 10S nur 36A Strom zieht?
Und kann vielleicht weiterhelfen...?
Vermute einen 1-Blatt Propeller bedeutet halb,
oder sie hat einen 2 Blatt Propeller zur Hälfte gekürzt...? :p
@ Techmaster
steht doch dran
"halfpropeller ... schambech"
ist ein KTW von Florian Schambeck mit 1-Blatt Propeller
Dauerstrom max: 40A
maximaler Strom für 15 sec: 50A
11S Lipo ist ein Versuch wert, aber Strom messen und dabei je nach Strom max Motorlaufzeit bestimmen.
Thomas
Okay, habe mich noch nicht mit 1-Blatt Propellern beschäftigt und auch noch nie Schambech gehört.
Half-Propeller bedeutet für mich, - ein halber Propeller... :p:D
Habe nur diese Spezifikationen gefunden :
ESC: 77 bis 90A
and 1900 Watt (max)
Deshalb würde ich auch ne Zelle mehr probieren, und es mit dem Ampere /Wattmeter überprüfen,
wenn man den 1-Blatt Propeller nicht zum Zweiblatt Propeller tauschen kann.
Wenn man zuwenig Bodenfreiheit unter dem Modell hat, sollte man ja einfach ein Blatt mehr am Propeller nehmen um auf die richtige Leistung zu kommen.
Aber es könnte auch ein Motorsegeler sein, wo der Motor oben auf dem Modell sitzt, so habe ich mal einen Einblattpropeller verbaut gesehen...
Da wir aber nichts vom Modell wissen, sind das alles nur Vermutungen... ;)
NICATO
thanks all.;)
yes, is a motorsegler; motor retractable over the fuselage with only half propeller (1 blade 20x14)
