Mistersmoe90
Marchetti SF 260 from Carf. Yellow color
moki 100 with Mejezlik carbon propeller and nose cone.
Hitec servos
behotec air retracts with double valve from jetronic
single jetronic valve for brakes
jeti box cb200 with jeti becs to keep voltage on 5.9v
2 jeti rsat
light system from unilight
Revoc protection bags for wings and stabs
Pilot doll for deco
powerbox smoke pump
ignition battery
motor was measured at 85dB on full power
plane has the following damages: light scratches on the belly (cosmetic only)
one of the wing tanks was damaged and repaired (can be ordere from Carf for 70€)
motor cowl was slightly cracked and repaired (not yet repainted. It is also a cosmetic damage more than anything else)
Minor defects from the molding were filled with epoxy (not yet repainted. Cosmetic only)
the front landing light is missing (the led light only,the projector itself is still available)
the plane flies very well and the Moki 100 does a wonderful job for realism and power is sufficient for traditional accro.
I am selling it to get cash for new winter projects.
It is a private sell,no warranty, no returns.Due to the size and price of the machine, I prefer to sell it at home so you can inspect it properly and i can show you everything.
ready to fly with jeti system: 5500€
without cb200, sats and servo batteries 5300€
Hitec servos
2 jeti rsat
Pilot doll for deco
powerbox smoke pump
ignition battery
- Preis
- 5500
- Zustand
- Good
- Versandart/-kosten
- Pick up
- Artikelstandort
- Ramillies, Belgium
