Otto Jaeger
Consider selling a brand new Prestige 2PK Pro Light V-tail.
Sold below self-cost. Bought new from Samba with fully assembled ids and servos in the wing. Test flight two days, approx. 6 - 8 trips to see everything working perfectly. Absolutely 100 percent mint condition!!
Servos in the wing are KST X10 mini on flap, KST HS08 on aileron and MKS HV 6110 on V-tail. Absolutely no slack! Set up with an Xpower F2919/10 motor, YGE 35 LVT regulator, GM 30 spinner and GM 10 x 6 propeller. To get the weight as low as possible, 1220 grams, a nose from Phoenix is fitted. This is 50 mm longer than the original, and makes it possible to use lighter equipment. Battery used is Tattoo 4S/550 95C of 60 grams Original nose included, fully drilled for "16/19" engines. With the original nose and the same cg (approx. 110 mm), the model weighs approx. 1280 - 1290 grams. The V-tail is of the FAI type. That is light!
Comes with original complete covers for body and wings. The model is also prepared for the use of ballast in the body. Receiver/Altis are basically not included.
Here you have the opportunity to get hold of a new, unique model from one of the world's best suppliers.
The model can be shipped. Has the original box from Samba.
The flight characteristics of this model cannot be described. Must be experienced!
- Preis
- 3000
- Zustand
- New
- Versandart/-kosten
- Buyer
- Artikelstandort
- Norwegen
