Neue Version RTG Orden V2?
It's simply hard to understand a situation in which you praise every model and then it is not supported by your sports career because you don't use it there.
You simply show many of these models in one propaganda film, and then they disappear completely and I don't see them at competitions or in your subsequent films. It's a bit like judging a book by its cover, don't you think? .
I believe that it is impossible to fairly evaluate a model after an hour, a week or a month of flying, especially if you do not test this model in a competition.
For me, such an assessment is a kind of hypocrisy and it does not apply only to you, but to all types of advertising films in general, and according to EU law, they must include information about paid promotion (and paid means any form of gratification).
If you receive a model from the manufacturer and then make a film about it, isn't this a form of advertising? (I don't think you buy all these models just to make one video and put it in the closet...)
Of course, competition favors us, but it affects the prices of average models rather than the best ones. You look at the Freestyler or Pitbull website and nothing is cheaper there. And there is no need to advertise anything because these models advertise themselves with their sports results.
I assume that most advertisements are a sign of desperation of producers who are not selling something and decided that someone has to promote them.
For me you are still a great pilot and competitor. And treat it not as an attack on you, but as my view on all kinds of advertisements and promotions. Which I judge by standing firmly on the ground and maintaining a cool judgment of the situation. Treat it as a sign that I don't pretend, I don't hide what I see, I just write how I perceive these and other forms of advertising.
Hallo an Euch
Ein Orden+ in der Strongversion ist auf dem Weg zu mir.
Werde gerne berichten...
Bildquelle: Hersteller
ich beziehe mich jetzt auf meinen Text im Trade Nr. 9
Mit dem V-Leitwerkgewicht meinte ich, dass gegenüber dem 1. ORDEN + das Gewicht des 2. Orden + insgesamt um ca. 25 leichter auf komplett ca. 55 g. von RTG gebaut wurde. Somit braucht es für den Schwerpunkt des Modells deutlich weniger Gewicht in der Rumpfspitze.
Weiterhin habe ich den Graupnerempfänger GR 16 aus dem Gehäuse genommen und in einen Schrumpfschlauch eingeschrumpft. Somit konnte ich zuerst alle Servokabel einstecken und den Empfänger unter dem Servobrett für die Höhenruderservos, bis zum Flächenverbinder hindurchschieben. Siehe Foto. Dadurch hatte ich im Rumpfvorderbereich genügend Platz für Akku und Schwerpunktgewicht. Natürlich habe ich die beiden Antennen nach vorne in den Kevlarbereich verlegt. Das Gesamtgewicht des 2. ORDEN + beträgt nun Flugfertig ca. 2300 Kg.
Gruß Jürgen
masaga
Welche Servos kommen in den Rumpf? Hab jetzt nämlich nur Rumpf + Lw bestellt, die Flügerln sind nämlich schon vorhanden 😊 Bin schon gespannt, wie sich der Unterschied zu v1 zeigt
masaga
Nachdem der Rumpf kürzer sein sollte wie der von V1, passen dann immer noch die 18650er-Zellen, oder eher die 18500er?
Hello, I managed to use 2 x 18650 cells despite the shorter nose. The case of the REX6 is 3D printed, but the original case should possibly work too.
hier mein neuer ORDEN +( PLUS ). Einfach wieder eine sehr gute Qualität. So wie man es von RTG Modellbau kennt. Das Gewicht beträgt Abflugfertig bei einem Schwerpunkt von 97 für den Hang bei ca. 2210 g.
madmao
Das kurze Näschen steht ihm gut....
Ich habe mir noch den Orden E Rumpf nach bestellt und diesen nun auch bekommen.
Laut Milan passt das V-Leitwerk des Orden+ nicht zum Orden-E daher gabs noch ein weiteres V-Leitwerk dazu.
Hier ist mal mein angedachtes Setup:
Motor: Tenshock EDF 1530-10T-2750 KV
Getriebe: Micro Edition 5:1 N
LS: GM CFK 17 X 10
Welches Setup fliegt ihr so in Eurem E-Orden?
André
madmao
Übrigens, habt ihr mein Design geklaut? 😂😂
