Danger check servo MKS HV69
Gery
Danger, be careful
strong acceleration over 30G (maximum reported by the Mav sense EX5K sensor)
possible movement of the servomotor inside the box
Caput model
Thanks for the information.
I never expected that the G-loads on a servo could cause problems.
I'm sorry about your model
Gery
the motor is not fixed, the housing is greased.
the servo motor weighs 7g.
with a weight of approximately 15 g slide out
on existing models I drill a side hole on the servo and inject cyanoacrylate
The backlash on my MKS HV6130 is really impressive small, but on the other side, 2 out of 5 new servos were not working out of the box. Seems MKS has an issue with quality control.
KST will be my choice from now on I think.
Sorry for your kaputt model.
Gery
KST is OK , but be careful KST A13-610, sensitive to temperature, I have to trim every flight
On my next DS Glider I will check out the CHA hv 95 on aileron and the KST A12 on Flaps....
I'm exciteted to explore the performance of these servos.
Cheers Robert
Gery
KST A13-610 do not use for very fast DS. Motor and gearbox correspond to the 12 mm thick KST A12-610.
Much better is the KST A12 Torque V8 · 12 mm digitales HV-Servo bis 200 Ncm.
on my electric DS model used for slope exploration
Aileron X 10
Flap A13-610
light model < 100 g wing loading I don't have any problems with gear wear
but I have to trim the A13-610, every flight
next model > 200 g wing load A12 Torque.....get ready for the new order
17mm is out of range for my DS Gliders...neither nor in the fuselage or wings...
What a DS-Monster are you planning for this servo...
I have tested the 8mm Cha only, and the current draw is very very high. So high, that the housings heat up to 30+ degrees, even without any load. It seems that they have a very aggressive software.
In an F3K, this reduced the flying time to 30-45min. With KST and same battery, the flying time is several hours.
Gery
no monster, heavy model , obese :D
as per the photos I have space
think 03 servos (02 flap 01 Tail) with max current 35.4 A outside of reason
as you can see on the MKS HV 69 servo I made a hole and glued the motor forever ( clevis servo steel )
This isn't a good recommendation for the reliabillity of this servo....🧐....I hope that the HV 95 isn't overpowered.
