schmuki1972
Verkaufe fast nicht gelaufenen Typhoon Impeller 2W23 2950KV
For pylon /EDF jets up to 1600 grams
Suitable for HET EDF unit 6904 or WeMoTec 480 mini fan
Spec.:
-Diameter : 28 mm
-Length : 47 mm
-Shaft Dia. : 3.17 mm
-Weight : 100 grams
-No load current(lo) : 2.4
-Internal resistance: 0.015
-KV : 2950
-No. of poles: 6
-Max Current: 75 A
-Max efficiency: 87%
-Power Nominal: 850 Watts on 5 cells
-Advance timing : 18° Middle
-PWM: 16 Khz
Note: Don't run 2W-23 for over 30 seconds at full throttle. On 5s the RPM is close to 45000 in our 6904 fan unit. It is better to use throttle management. After flight cool the motor for 20-30 seconds at low RPM
Spec.:
-Diameter : 28 mm
-Length : 47 mm
-Weight : 100 grams
-KV : 2950
-No. of poles: 6
-Max Current: 75 A
-PWM: 16 Khz
- Preis
- 45
- Zustand
- 2
- Versandart/-kosten
- 5,90
- Artikelstandort
- 93485
