martin_magnus
habe eine neue Radiomaster Zorro ELRS bekommen, auf die ich das neueste EdgeTX istalliert habe.
Leider bekomme ich mit ExpressLRS-Konfigurator keine Verbindung:
Traceback (most recent call last):
File "runpy.py", line 196, in _run_module_as_main
File "runpy.py", line 86, in _run_code
File "C:\Users\mail\AppData\Roaming\ExpressLRS Configurator\firmwares\cloud\ExpressLRS\499697ca7efc099050868d30578368a75df63d72\firmware\flasher.pyz\__main__.py", line 3, in <module>
if __name__ == '__main__':
File "C:\Users\mail\AppData\Roaming\ExpressLRS Configurator\firmwares\cloud\ExpressLRS\499697ca7efc099050868d30578368a75df63d72\firmware\flasher.pyz\_bootstrap\__init__.py", line 253, in bootstrap
File "C:\Users\mail\AppData\Roaming\ExpressLRS Configurator\firmwares\cloud\ExpressLRS\499697ca7efc099050868d30578368a75df63d72\firmware\flasher.pyz\_bootstrap\__init__.py", line 38, in run
** Searching flight controllers **
> FC found from 'COM5'
Detected the following serial ports on this system:
File "C:\Users\mail\.shiv\flasher.pyz_262fe24b88813beb8f908866f759f19c90cb1dc03110afa4d8fa2285ad5d90b4\site-packages\binary_configurator.py", line 427, in main
return binary_flash.upload(options, args)
File "C:\Users\mail\.shiv\flasher.pyz_262fe24b88813beb8f908866f759f19c90cb1dc03110afa4d8fa2285ad5d90b4\site-packages\binary_flash.py", line 193, in upload
return upload_esp32_etx(args)
File "C:\Users\mail\.shiv\flasher.pyz_262fe24b88813beb8f908866f759f19c90cb1dc03110afa4d8fa2285ad5d90b4\site-packages\binary_flash.py", line 118, in upload_esp32_etx
args.port = serials_find.get_serial_port()
File "C:\Users\mail\.shiv\flasher.pyz_262fe24b88813beb8f908866f759f19c90cb1dc03110afa4d8fa2285ad5d90b4\site-packages\serials_find.py", line 71, in get_serial_port
raise Exception('No valid serial port detected or port already open')
Exception: No valid serial port detected or port already open
