new project around corner, working with original blueprints of Messerschmitt, a lot of scratch build, as i already made one rodelmodel me 109 in Gustav G10 variant. Tail almost completed.
An absolutely marvellous kind of work that you did! I´ld never have enough patience to produce such a piece of art. And if ever would have, I would never ever fly it.
Congratulation - Perfect finish - the tailwheel suspension seems "special" - was it one of the retractable versions? - lots of further successful flights and happy landings, Claus
Was die Seriennummer angeht, bleibt es also immer noch eine Vermutung, aber mit Sicherheit handelt es sich um G-14AS. Auch dieser Text zur Triebwerksgondel ist wahrscheinlich auf Kroatisch für Mechaniker verfasst. Aber im Moment spekulieren Historiker nur.
Beste Grüße, Tom
