Anzeige Anzeige
BZ-Modellbau
Seite 1 von 2 12 LetzteLetzte
Ergebnis 1 bis 15 von 24
Thema: The RC Custom Jets F-18
  1. #1
    09.12.2006
    Huizen
    355
    Daumen erhalten
    2
    Daumen vergeben
    11
    0 Nicht erlaubt!
    Standard The RC Custom Jets F-18
    Started building the The RC Custom Jets F-18 because I can deliver the The RC Custom Jets models and want to give the right information to the possible buyers of these models.
    Length: 2100mm
    Wingspan: 1400 mm
    Engine: 120mm EDF of 8 tot 12Kg turbine
    Weight: 8-11kg
    Haven`t decided yet if I will make it EDF or turbine, turbine is something I prefer but will see what the total weight will be finally.
    Lasercutting by Sebastiaan from RC-Europe:
    RemoteJets, everything for your rc jets................................
  2. #2
    09.12.2006
    Huizen
    355
    Daumen erhalten
    2
    Daumen vergeben
    11
    0 Nicht erlaubt!
    Standard
    Started with the wings:
    Eerst de standaard in elkaar zetten waar de vleugels op gebouwd worden:
    Search for the ribs and go glue:
    That was quick.
    First making ailerons and flaps and decide were to put the servo`s.
    After that wing tube and then I can sheet the bottom.
  3. #3
    User Avatar von Marksman
    21.10.2010
    Darmstadt
    12
    Daumen erhalten
    1
    Daumen vergeben
    0
    1 Nicht erlaubt!
    Standard
    Nice Job (Plane). I'm looking forward...
  4. #4
    09.12.2006
    Huizen
    355
    Daumen erhalten
    2
    Daumen vergeben
    11
    0 Nicht erlaubt!
    Standard
    Thanks.
    Aileron also 'finished':
    Some 'scrap' material used for stiffening the spar, the middle original spar will also be cut for the hinges:
    Used some extra balsa behind the spar for more grip:
    Sheeting:
    Leading edge made out of balsa strips:
    Later filling and sanding.
  5. #5
    09.12.2006
    Huizen
    355
    Daumen erhalten
    2
    Daumen vergeben
    11
    0 Nicht erlaubt!
    Standard
    Same story for the flaps:
  6. #6
    07.04.2013
    - Calvados
    15
    Daumen erhalten
    1
    Daumen vergeben
    0
    0 Nicht erlaubt!
    Standard
    very interesting, I look forward to the rest of the construction and maiden flight
  7. #7
    09.12.2006
    Huizen
    355
    Daumen erhalten
    2
    Daumen vergeben
    11
    0 Nicht erlaubt!
    Standard
    Making the aileron openings:
    And flaps:
  8. #8
    09.12.2006
    Huizen
    355
    Daumen erhalten
    2
    Daumen vergeben
    11
    0 Nicht erlaubt!
    Standard
    Added some balsa on the trailing edge for the hinges:
    Added leading edge, after this I can cover the bottom side of the wings:
  9. #9
    09.12.2006
    Huizen
    355
    Daumen erhalten
    2
    Daumen vergeben
    11
    0 Nicht erlaubt!
    Standard
    Ik was ook al een heel stuk opgeschoten met de romphelften:
  10. #10
    09.12.2006
    Huizen
    355
    Daumen erhalten
    2
    Daumen vergeben
    11
    0 Nicht erlaubt!
    Standard
    Started with sheeting:
    Misty is helping a lot
    and decided to sheet the intakes instead of using the 'mold':
  11. #11
    09.12.2006
    Huizen
    355
    Daumen erhalten
    2
    Daumen vergeben
    11
    1 Nicht erlaubt!
    Standard
    And sheeting go`s on:
  12. #12
    09.12.2006
    Huizen
    355
    Daumen erhalten
    2
    Daumen vergeben
    11
    0 Nicht erlaubt!
    Standard
    The formers for the landing gear mounts needs to be modified a little, in future kits this will be done.
    Width is now 18mm and needs to be 22mm to fit the ER-30 or JP ER-120`s:
    Hardwood:
    The ER-30`s will fit:
    Enough free space at the air intake:
  13. #13
    09.12.2006
    Huizen
    355
    Daumen erhalten
    2
    Daumen vergeben
    11
    0 Nicht erlaubt!
    Standard
    Because I didn`t like the fact that the vertical stabilizers needs to be build up directly with the fuselage I decided to slight them in later, therefor I needed to remove the notches:
    The vertical stabilizers will be sheeted with 3mm balsa:
  14. #14
    09.12.2006
    Huizen
    355
    Daumen erhalten
    2
    Daumen vergeben
    11
    0 Nicht erlaubt!
    Standard
    I also decided to use bearings on the elevators.
    6mm steel and aluminum horn I allready needed, extar are the bearings:
    Needed to modify the former on the inside slightly:
    And on the outside:
  15. #15
    05.04.2011
    houthalen
    39
    Daumen erhalten
    0
    Daumen vergeben
    3
    0 Nicht erlaubt!
    Standard
    Doing a great job at lightspeed.
Ähnliche Themen
  1. L39 von The RC custom jets
    Von wolfgang30 im Forum E-Impeller Jets
    Antworten: 32
    Letzter Beitrag: 20.10.2019, 20:18
  2. Eurofighter 1/3,7 RC custom Jets Maiden
    Von Vampire im Forum Turbinen Jets
    Antworten: 7
    Letzter Beitrag: 18.08.2019, 17:21
  3. The RC custom jets
    Von wolfgang30 im Forum Turbinen Jets
    Antworten: 8
    Letzter Beitrag: 30.01.2017, 14:11
Berechtigungen
