www.unilight.at
Seite 2 von 2 ErsteErste 12
Ergebnis 16 bis 24 von 24
Thema: The RC Custom Jets F-18
  1. #16
    09.12.2006
    Huizen
    355
    2
    11
    Thanks.
    And more sheeting:
    RemoteJets, everything for your rc jets................................
  2. #17
    09.12.2006
    Huizen
    355
    2
    11
    And received today the retracts from JP:
    Will need to modify the main legs a little but will show how and what later when other fuselage half is almost finished.
  3. #18
    09.12.2006
    Huizen
    355
    2
    11
    More sheeting on the fuselage:
    Vertical stabilizers fully sheeted:
    And elevator parts glued,sheeting will follow later:
  4. #19
    09.12.2006
    Huizen
    355
    2
    11
    6mm steel control rods bend:
    Looking good:
    Started with 3mm balsa sheeting:
  5. #20
    09.12.2006
    Huizen
    355
    2
    11
    And more sheeting:
  6. #21
    09.12.2006
    Huizen
    355
    2
    11
    Elevator rods glued:
    And elevator somewhat balanced:
  7. #22
    09.12.2006
    Huizen
    355
    2
    11
    Just a few sheets to go and 1 fuselage half will be ready:
  8. #23
    09.12.2006
    Huizen
    355
    2
    11
    Slowly started with sheeting the other fuselage hafl.
    From the vertical stabilizers I have sanded the leading and trailing edge in shape.
    Then cut the rudders and shape that leading edge and test fitted the hinges:
    After a light sanding session I can glass the vertical stabilizers and rudders, when that is finished I can glue the hinges in place.
  9. #24
    09.12.2006
    Huizen
    355
    2
    11
    Started glassing the vertical stabilizers:
  1. L39 von The RC custom jets
    Von wolfgang30 im Forum E-Impeller Jets
    Antworten: 32
    Letzter Beitrag: 20.10.2019, 20:18
  2. Eurofighter 1/3,7 RC custom Jets Maiden
    Von Vampire im Forum Turbinen Jets
    Antworten: 7
    Letzter Beitrag: 18.08.2019, 17:21
  3. The RC custom jets
    Von wolfgang30 im Forum Turbinen Jets
    Antworten: 8
    Letzter Beitrag: 30.01.2017, 14:11
