H-King Jetstar 64mm 11-Blade EDF Jet 800mm (31.5") PnF
stocky
Moin zusammen,
den Jet habe ich gerade als Neuvorstellung bei Hobbyking gefunden.
https://hobbyking.com/en_us/jetstar-pnp.html?affiliate_code=GYXMHLJMEFLNYUB&_asc=8484693150
Leider kann ich über mein Handy hier keine Bilder einstellen.
Für mich sieht das nach einem Stinger 64 in größer aus an dem noch eine große Kabinenhaube verbaut wurde.
Könnte eine Menge Spaß machen denke ich. Das das Fahrwerk nötig ist glaube ich nicht.
Wäre schön wenn mal irgendwann jemand darüber berichten könnte. Mein Hangar ist im Augenblick zu voll.
Gruß Reimund
stocky
The H-King Jetstar EDF Jet takes you to the next level of performance. The 11-Blade 64mm EDF will give you the power to burn as well as that realistic jet sound. As it is only 940mm long it will be easy to transport to the nearest flying field.
Made of strong EPO foam and a quality build this jet will soar through the air. Build time is kept to a minimum as servos, motor, ESC and EDF are pre-installed. Its great looks and sleek lines are enhanced by the factory fitted decals. The large battery hatch will make installing the receiver (not supplied) and battery (not supplied) a breeze. It comes with a steerable nose wheel to provide better ground handling.
Once in the air, there is plenty of power with a 1:1.2 thrust rate provided by the 4S EDF system. This will make all aerobatics and fast low-level passes just so easy. It comes with a rudder so you should be able to try a few knife edges. This plane is built to fly.
The sky is where you want to be, so get the Jetstar now and hear that realistic jet “whoooosh”.
Features:
• Made of strong EPO foam
• Plug-in wings with strong magnets for fast assembly and the ability to fly at high speed
• Motor, EDF, Servos and ESC are factory pre-installed
• Large canopy for easy battery access and RC installation
• H-King 11-blade EDF produces a realistic “Whooshing” gas turbine jet sound
• Factory-applied decals
Specs:
Wingspan: 800mm (31.5”)
Length: 940mm
Flying weight: 900-1000g
Thrust rate: 1:1.2
Motor: D2839-3300KV
EDF: 64mm (11-blades)
ESC: 60A Brushless
Servo: 9g plastic gear x 4pcs + (elevator) 9g metal gear x 1pc
Flight time: about 5 mins
Requires:
1 x R/C Radio System (T/RX)
1 x 2200mAh 4S Lip
Christian Abeln
Auch hier: Darfst Du die Bilder verwenden? Quellennachweis?
Leute beachtet bitte das copyright... Einfach so von irgendwoher Bilder einstellen haut nicht hin. Auch wenns von ner Herstellerwebsite ist.
Wenns eure eigenen Bilder sind ist das kein Problem...
MadEff
maddyn
HI
der antrieb is bischen anders
Amewi 40a regler
hk 60a
amewi motor 2830 3850kv
hk 2839 3300kv
auch bei den servos
amewi 5x9g
hk4x9g 1x9g metall
auch in der flugzeit sind deutliche unterschiede von 4 auf 7minuten
MadEff
Nene, nix Recherche.
Gedächtnis.
Ich bin noch Prä-Google und merke mir Dinge, die ich einmal gesehen habe. :D
Der Amewi Jetstar ist allerdings für 3S ausgelegt, nicht für 4S wie der vom Hobbyking.
Daher vermute ich zumindest, dass der Antriebsstrang ein anderer ist.
Prima... wenn ich künftig was wissen möchte, spare ich mir das Googlen und frage gleich dich direkt... :D
stocky
Sorry, aber über die Bilder habe ich mir keine Gedanken gemacht da das hier ja fast schon standart ist. Jedenfalls wenn es um Hobbyking geht.
Aber trotzdem danke für den Hinweis und du hast ja auch recht.
