Nightmare MK VII
Hello from Hvar Croatia.
My name is Igor and i am interested in making trimaran.
I looked Firedragon, Nightmare MK VII and MK VIII.
Plan that i downloaded from RC. SAILS are pretty hard to understand for beginner so i choose Nightmare MK VII which is little easier to understand.
BUT, there are 4 kinds of Nightmare MK VII in one PDF. There are :
HR Uebersicht060719
HR Uebersicht-rund060719
HR-Uebersicht 060729
HR-Uebersicht rund 060729
Thank you for any kind of help.
Hi Chris
Thank you for your reply, i will go then with last version, the round one HR-Uebersicht rund 060729.
That is glass fiber, what g/m² is hull and crossbeam?
By the way nice paint job on that trimaran.
Thanks
You can use two times 160g glass for the hulls and reinforce with a third layer or 200g where needed, eg where the beams are attached. For the beams I use two times 200g carbon. Maybe a 50g glass layer will help making the hulls watertight. But there are many layups possible.
Ok thank you
I am at the moment making pogo3/imoca/class 40 1 meter sailboat, so when i finish that i will start with multihull.
