MIG 21 MF 1/3,8 scale
F86_SABRE
MIG-21
MIG-21
Hi Mugurel
Here is some information. Check with your drawing. This may help
Reuben
  • MIG-21a.pdf
  • MIG-21b.pdf
  • MIG-21c.pdf
  • MIG-21d.pdf
Mugurel,
Forget that plan that you used, nothing is scale enough on it, everything is not correct.
It is the best idea and easier way to start a new fuselage than to modify the one you built via that semi-scale plan.
Get Eduard MiG-21MF 1/48 kit, slice it to get cross sections, enlarge them and work from there .. :)
Use a lot of the real MIG photos from internet and make corrections accordingly to them.
Sounds easy, but it would take some effort, however that way the model you are building would be much more scale. :)
Taking into the account a lot of the hard work, time, money and effort, it would be a well worth it to make the MIG more correct in scale .. :)
Best regards,
Kris
F86_SABRE
MIG-21
MIG-21
Some more detail here
  • Pages from Jakab 7 MiG-21 in Czechoslovak AF 1962-2005 vol.1.pdf
  • Pages from HISTOIRE & COLLECTIONS - MIG-21.pdf
F86_SABRE
MIG-21
MIG-21
Hello MUGUREL
The drawings I included here are just meant to help you only and not to highlight any differences of your work. I appreciate all the work you are doing and wish you all the success too!. Also, plastic kit models are not always 100% correct. Again, I wish you all the best and let me know if I can be of more help as I have a lot of Mig-21 information in digital format. :cool:
Reuben
Litle work today! 2176EB17-F84F-4DC2-96FC-D0B1C6C5F2AD.jpeg1CA0C988-944F-4670-B147-CA6E5A77ADDA.jpeg3F129DA0-C868-47E8-8E13-83377AA3AA07.jpeg14C24CBE-B86E-4715-8248-69125E9427A1.jpeg
eug
Foam type?
Foam type?
Murgurel
What kind of foam is this? the reddish coloured one..
Thank you,
Christof
F86_SABRE
MIG-21
MIG-21
I asked the same question some time ago on another channel. Here is what he said:
"thank you! the pink filler is normal poliuretan foam,is very easy to work with this!"
Hope this helps
Reuben
MarkusD
Bauschaum - MDI (isocyanate) and Castor oil in a 2pack bottle
Gibt es in Deutschland aufgrund des isocyanates nicht mehr „einfach so“ im Baummarkt
Warum seiner rot ist - denke das der Hersteller den leicht einfärbt, sonst sind die ja meist leicht gelblich
Mugurel,
Plan that you used for the fuselage is not even close to scale, even the cross sections are too much in error.
Please see at the picture below, that F6 scale cross section it should be very close to the red line:
I am sorry and apologizing if I bother you too much, but my intention is really to help you to make the MIG more scale,
considering of the so much hard work you plan to use here for creating this beautiful model. :)
Best regards,
Kris
