NURFLIDL, modidfizierter LIDL XL-GLIDER
Zur Info für die Österreicher: Den EXAKT gleichen Schaumflieger hat derzeit der Hofer um 8 Euro im Angebot. Habe mir gerade zwei besorgt und kann versichern, dass die Schaumteile die gleichen wie beim Lidl-Flieger sind.
Ja das stimmt. Die Verpackung ist anders und beim Hofer sind die Flügel gelb. Zumindest bei meiner Version. ToyLINO vom Hofer. Playtive vom Lidl von 2021
DonM
Nurflidl aber die alte Version, in den Niederlanden an der Küste.
Zusammen mit dem Lidl Bruder an der Küste.
Endlos lange Dünen 😎
Gruß DonM
DonM
Maiden flight with my new build Nurflidl today 😀
22-28 knots wind, 100 gram extra inboard ballast and CG at 38 mm, 2 x HXT 900 servos, 4 x AAA Nimh battery.
Cheers
Soren
Hi Soren,
what a wonderfull flight.
My older Nurflidl its to light for the Wind here in NL, my complete weight is 288gr.
and the CG at 39,5mm. I think, I Must use more Ballast for the Wind 😉.
The Nurflidl flights very good and I have lot of fun today 😎
Cheers Manfred
Huffa
Hi Søren,
good job!! Due to white wing and red fuselage I guess you made it from the 2021 glider version?
If so, could you please explain the way you built the wing?
Did you cut off some foam at the trailing edge to make the edge thicker and stronger (similar to the older version) before fixing the ailerons?
Thank you for sharing and explaining!
Cheers
Stephan
Hi Søren,
Cheers
Stephan
Hi Stephan
It is one of the old versions with the thick trailing edge, and the same with this yellow one.
I just made this one today the same way :)
In the wing I first made a cut in the leading edge that will be inside the fuselage, and together with a hole in in the fuselage this is the ballast room for up to 100 gram extra inside ballast.
And there is no extra wing spar, wing just glued in the fuselage with hot glue.
And the outher ailerons are pulled by a small piece blenderm tape,
3 mm balsa ailerons.
Cheers
Soren
Nurflidl neue 2021-Version
Hier meine ersten Eindrücke zum Nurflidl auf Basis der neuen 2021-Modell-Version:
  • Funktioniert grundsätzlich alles recht ähnlich wie mit der alten Version.
  • Wie von @bodobob in #307 vorgeschlagen, habe ich die Tragflächenhinterkante bei ca. 16mm Tiefe abgeschnitten, um so einen 6mm-Anschluss für die 6x45x1cm Ruder zu bekommen.
  • In der Mitte sind die Tragflächen etwas dicker, da muss man hinten oben auf 6mm runterschleifen, wenn man einen sauberen Übergang zu den Rudern haben möchte.
  • Den Rumpf habe ich mit 9,5cm von der (ursprünglichen) Tragflächenhinterkante kurz gehalten, damit ich vorne wenig Ballast brauche; Abfluggewicht somit 225g.
  • Für stärkeren Wind kann ich mit 3x50g aufballastieren.
  • Flugeigenschaften: gut vergleichbar mit der alten Version, nur dass der neue Nurflidl deutlich bessere Loopings schafft – eine sehr positive Überraschung!
  • Der optimale Schwerpunkt scheint mit etwas weiter vorne als bei den sonst üblichen 38mm zu liegen; allerdings bin ich zur Schwerpunkt-Frage noch nicht ganz sicher; ist noch nicht ganz fertig eingeflogen.
Fazit: Das neue Modell scheint mir ein durchaus tauglicher Nachfolger zu sein, der mit seiner Looping-Freudigkeit sogar einen erfreulichen Vorteil mitbringt.
Vielen Dank an @wst, der mir selbstlos ein 2021-OVP-Lidlglider geschenkt hat, und an @FliegerMuellero und @fc-shuttle für die zahlreichen Bau- und Einflieg-Tipps.
Schotti
Hallo Jungs,
ich habe 3 Stück ergattert und will auch eine NurflügelVariante basteln.
Aber die links am Anfang von Hernn Schweisgut gehen nimmer.
Gibt´s sonst irgendwo einen nachvollziehbare Anleitung?
thx.
