Hallo bin mir eine CG Waage zubauen , mein Problem sind die Arduino Libraries
Arduino: 1.8.11 (Windows 10), Board: "Arduino Nano, ATmega328P"
CG_scale_AMa_mod2017.ino:85:25: error: no matching function for call to 'HX711::HX711(const uint8_t&, const uint8_t&)'
HX711 front_scale(A2, A3);
In file included from C:\Users\Andre\AppData\Local\Temp\Temp1_CG-scale-mod-master.zip\CG-scale-mod-master\CG_scale_AMa_mod2017.ino\CG_scale_AMa_mod2017.ino.ino:1:0:
C:\Users\Andre\Documents\Arduino\libraries\HX711/HX711.h:22:3: note: candidate: HX711::HX711()
HX711();
C:\Users\Andre\Documents\Arduino\libraries\HX711/HX711.h:22:3: note: candidate expects 0 arguments, 2 provided
C:\Users\Andre\Documents\Arduino\libraries\HX711/HX711.h:19:7: note: candidate: constexpr HX711::HX711(const HX711&)
class HX711
C:\Users\Andre\Documents\Arduino\libraries\HX711/HX711.h:19:7: note: candidate expects 1 argument, 2 provided
CG_scale_AMa_mod2017.ino:86:24: error: no matching function for call to 'HX711::HX711(const uint8_t&, const uint8_t&)'
HX711 rear_scale(A0, A1);
HX711();
class HX711
CG_scale_AMa_mod2017.ino:123:81: error: no matching function for call to 'LiquidCrystal_I2C::LiquidCrystal_I2C(int, int, int, int, int, int, int, int)'
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
In file included from C:\Users\Andre\AppData\Local\Temp\Temp1_CG-scale-mod-master.zip\CG-scale-mod-master\CG_scale_AMa_mod2017.ino\CG_scale_AMa_mod2017.ino.ino:7:0:
C:\Users\Andre\Documents\Arduino\libraries\LiquidCrystal_I2C-1.1.2/LiquidCrystal_I2C.h:57:3: note: candidate: LiquidCrystal_I2C::LiquidCrystal_I2C(uint8_t, uint8_t, uint8_t)
LiquidCrystal_I2C(uint8_t lcd_Addr,uint8_t lcd_cols,uint8_t lcd_rows);
C:\Users\Andre\Documents\Arduino\libraries\LiquidCrystal_I2C-1.1.2/LiquidCrystal_I2C.h:57:3: note: candidate expects 3 arguments, 8 provided
C:\Users\Andre\Documents\Arduino\libraries\LiquidCrystal_I2C-1.1.2/LiquidCrystal_I2C.h:55:7: note: candidate: constexpr LiquidCrystal_I2C::LiquidCrystal_I2C(const LiquidCrystal_I2C&)
class LiquidCrystal_I2C : public Print {
C:\Users\Andre\Documents\Arduino\libraries\LiquidCrystal_I2C-1.1.2/LiquidCrystal_I2C.h:55:7: note: candidate expects 1 argument, 8 provided
C:\Users\Andre\Documents\Arduino\libraries\LiquidCrystal_I2C-1.1.2/LiquidCrystal_I2C.h:55:7: note: candidate: constexpr LiquidCrystal_I2C::LiquidCrystal_I2C(LiquidCrystal_I2C&&)
C:\Users\Andre\AppData\Local\Temp\Temp1_CG-scale-mod-master.zip\CG-scale-mod-master\CG_scale_AMa_mod2017.ino\CG_scale_AMa_mod2017.ino.ino: In function 'void setup()':
CG_scale_AMa_mod2017.ino:211:7: error: 'class LiquidCrystal_I2C' has no member named 'setBacklightPin'; did you mean 'setBacklight'?
lcd.setBacklightPin(3,POSITIVE);
setBacklight
CG_scale_AMa_mod2017.ino:211:25: error: 'POSITIVE' was not declared in this scope
Mehrere Bibliotheken wurden für "HX711.h" gefunden
Benutzt: C:\Users\Andre\Documents\Arduino\libraries\HX711
Nicht benutzt: C:\Users\Andre\Documents\Arduino\libraries\HX711_Arduino_Library
exit status 1
Dieser Bericht wäre detaillierter, wenn die Option
"Ausführliche Ausgabe während der Kompilierung"
in Datei -> Voreinstellungen aktiviert wäre.
HX711();
class HX711
HX711();
class HX711
setBacklight
exit status 1
