Baubericht - Fun Raven 2,20m von Weidner
josin
Ovidiu Hello, I have a friend who manufactures landing gear carbon, the original first test and then we'll see if you fixed on the picture that the Edge and Raven really that the air intake of the Edge is smaller than the Raven and not heated at all works perfect.
You can tell me where is your center of gravity Raven, thank you for everything.
FC28
Moin zusammen,
auch wenn es hier etwas Englisch geworden ist aber was wiegt euere Maschine den jetzt wo sie fertig ist?
Ich habe die noch in Styro Balsa und die wiegt mit einem DA 50 7,5 kg.
josin
Latest photos up within a month or less, I have to assemble and fly another plane that I have received today.
Hallo FC28,
nach meinem rechnung, mit alle teile fertig gebaut (ARF), sollte 7,6kg wiegen, aber mit sicherheit werde schwerer sein....denke ich um 8kg.
josin
Hello, this afternoon we released a raven, not this post, one of the three is on valencia, the flight is fantastic, and much fleet is very difficult to enter into desert, has only flown three times to adjust and others, Raven this with this motorized DA-50 and tuned-pipe K & S.
Judgements.
On the third landing was a dismembered leg of the landing gear, the landings have been very mild, thus failure of the train.
After putting the engine running and accelerating in the soil has left flying the cabin, adjudication of bolt's that the subject had been off as if they were, therefore ruling assembly factory.
After the third flight the same but with the cover of the engine, therefore ruling assembly factory.
These failures can not commit on a plane which costs € 1020
Photos
Hi Josin,
very nice photos!
Could you tell me please the total weight of the model?
We found also that the landing gear is too elastic for this weight. My flight collegue has replaced it with a Sukhoy-type one from elster modellbau. It is carbon made, stronger and offers a higher position of the model (I find it too high, but is better than a lower one on a bad field). I will put it also on my model.
Hallo zusammen!
Lezten wochenenden habe ich an flugzeug wieder gearbeitet und bin ich auf der lezten 100 meter bis zum ende des bau. Es folgt die bilder von den ganzen jahr arbeit:
SLW fertig bespannt und trennbar gemacht:
