BennyB.Good
Hello Steffen,
A warning came with my Castle ESC which says not to connect another power supply in parallel with the built-in BEC. In other words do not connect a 4 cell RX pack in parallel with the BEC.
The Castle ESC's have switching BEC's just like the three ACT BEC's that I got from you. I have always used 4 cell RX packs in parallel with my ACT BEC's and had no problem at all.
Other makers of some other switching BEC's warn against using a 4 cell RX pack in parallel with their products.
An exception is Kontronik, who RECOMMEND using a 4 cell RX pack in parallel with the BEC on their ESC's.
http://www.kontronik.com/images/stories/dmdocuments/anleitung_jive_2009_10_14.pdf (see p15)
Can you please find out if this is because the Kontronik BEC's are special in some way?
What could happen if I use a 4 cell RX pack in parallel with the BEC on my Castle ESC?
Does anyone else say it is ok to use a 4 cell RX pack in parallel with their BEC's?
